180 visninger | Oprettet:
PASSER DEN.? {{forumTopicSubject}}
Hey sg.
kan i læse om den her gearing passer eller ikk passer på min tyffe.. min er fra 97.
og jeg er ikk så god til engelsk..
;D
Taller gears in the transmission reduce the overall reduction factor of the gearbox. If the engine is powerful enough to pull the taller gears, this modification will also raise top speed. Only use with tuning kits! Original cylinders are normally not powerful enough to pull this sort of gearing.
Transmission ratio: Z=13-40 (3,07)+13.3%, shaft diameter: d=17.7 Watch out!!! In 1996 Piaggio changed their gearboxes. The diameter of the small shaft between primary and secondary gears for pre '96 models was 18.0mm, for post '96 it is 17.7mm. Measure if in doubt!
  • Solid dæk sæt på 400 kr.
  • Rengøring 500 kr.
Kommentarer på:  PASSER DEN.?
PASSER DEN.?
