154 visninger
HVA* BETYDER DET? {{forumTopicSubject}}
Hey sg.
http://www.scooter-attack.com/index2.php?lang=e
det der står i linket^^ betyder det at jeg KAN eller IKKE KAN få den gaering i min tyffe fra 97.?
kan ikk helt forstå det der Tysk-engelsk.. ;p
apr 2006
Følger: 80 Følgere: 78 Scootere: 13 Emner: 275 Svar: 879
eller er det denne som passer.?
;D
jul 2004
Følger: 24 Følgere: 24 Scootere: 1 Emner: 23 Svar: 373
//HoFFe
apr 2006
apr 2006
Transmission ratio: Z=13-40 (3,07)+13.3%, shaft diameter: d=17.7 Watch out!!! In 1996 Piaggio changed their gearboxes. The diameter of the small shaft between primary and secondary gears for pre '96 models was 18.0mm, for post '96 it is 17.7mm. Measure if in doubt!
apr 2006
haha
tak skal du have !
HVA* BETYDER DET?
