Athena 43mm problems {{forumTopicSubject}}
I have a Yamaha Fs1 1977 with following setup:
43mm Athena Aluminium
16mm carb
16mm intake manifold
180# dyse
"5.5" hk exhaustpipe
15/43 gearing
From what i have heard it should be the best "out-of-box" kit for the FS1. Is that true?
But my fs1 doesnt have nay high RPM at all.
My old 50cc Fs1 and my 60cc iron had alot more RPM, they did 80-85km/hour both.
This one only make 70km/hour, well it is Alot stronger and alot more "power from the bottom".
Shouldnt it go faster then?
Shall i change the nozzle (dyse) to 190-200 and change gearing to 16/43 or 17/43?
!!! Ni kan svara på danska!!!
apr 2004
Følger: 30 Følgere: 29 Scootere: 4 Emner: 148 Svar: 2.892
okt 2004
Følger: 25 Følgere: 23 Scootere: 1 Emner: 73 Svar: 1.719
gearing 14/43
jun 2005
Følger: 3 Følgere: 2 Emner: 21 Svar: 74
Is this cylinder bad?
It should go faster than 70km/tim right?
okt 2004
okt 2004
jun 2005
Even the 50cc could handle 15/43...
Why shouldnt this one do it?
This cylinder should be the best for Fs1?
okt 2004
jun 2005
But i dont think i have to buy that one.
Hm maby it is that simple that athena isnt a very good cylinder?
okt 2004
okt 2004
okt 2004
jun 2005
That sounds wierd :S
What about your cylinder, is it high RPM?
Like 10000+ or more?
What carburator and dyse do you use?
okt 2004
but maby the simering in the engine gets falls air
okt 2004
jun 2005
I will try them later..
And i have a 16 frontsprocket now also..
jun 2005
I need to know if it is my cylinder thats broken or something..
Does you cylinder takes many RPM?
I cant get if to go faster then 70km/tim.. :S
I have tried everything now..
