NYT STEAM FUCKER EFTER UPDATE CSS {{forumTopicSubject}}
maxplayers set to 32
Steam config directory: c:\program files\steam\steamapps\snowballdk\counter-strike source\platform\config
Unknown command "cl_thirdperson"
Can't use cheat cvar cam_snapto in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar cam_ideallag in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar cam_idealdelta in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar cam_idealyaw in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar cam_idealpitch in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar cam_idealdist in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar cam_idealdistright in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar cam_idealdistup in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar cam_collision in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar c_maxpitch in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar c_minpitch in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar c_maxyaw in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar c_minyaw in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar c_maxdistance in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar c_mindistance in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar c_orthowidth in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar c_orthoheight in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar cl_upspeed in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar cl_forwardspeed in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar cl_backspeed in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar fog_start in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar fog_end in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar fog_color in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar fog_colorskybox in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar fog_startskybox in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar fog_endskybox in multiplayer, unless the server has sv_cheats set to 1.
Can't use cheat cvar r_farz in multiplayer, unless the server has sv_cheats set to 1.
Network: IP 83.94.223.16, mode MP, dedicated No, ports 27015 SV / 27005 CL
Connecting to 81.167.61.169:27016...
Invalid Steam key size.
Connecting to 85.190.14.49:27015...
Connecting to 85.234.148.213:28015...
Det skriver den
Virker jeres CSS???
aug 2008
Følger: 17 Følgere: 16 Scootere: 2 Emner: 38 Svar: 158
prøv og re install lortet
evt lad vær med at hente alt muligt ko lort ned på din computer!!! fra fpsbanana eller hva fanden du bruger
nu har du lært det
sep 2004
Følger: 21 Følgere: 20 Scootere: 2 Emner: 39 Svar: 316
Hans Peter, Bruger dog ikke selv, men Fpsbanana ved sku hvad de snakker om, det er rigtige "nørder"
apr 2008
Følger: 34 Følgere: 28 Scootere: 7 Emner: 165 Svar: 407
sep 2004
